Message 1 of 15
Extension to modem
Hi
My name is Roger and it's my first time posting. I wonder if anyone can help.
I want to run a new cable from my master bt socket box to another one in a separate room and then connect to a nearby modem. Is this possible and if so what would be the best way  .  I appreciate any advice
Regards Roger
14 REPLIES 14
Message 2 of 15
Re: Extension to modem
The extension cable would not be a problem. Is this a shift of you existing modem or are wanting to add another?
(If I have helped you in any way please click the thumbs up. Thank You)
If I have solved your Issue please click the "Mark as accepted solution" button.
Message 3 of 15
Thanks for your response.  Its not another just moving the existing to another location
Roger
Message 4 of 15
I'm just not too sure about the wiring at the master and slave socket
Roger
Message 5 of 15
Hi @rbbrown2448   Instructions are normally included with extension kits or search YouTube or Google.
Anonymous
Not applicable
Message 6 of 15
If you have a filtered master socket then you need to connect the extension wiring to the data terminals in the master. If you don't need a phone in the new location you could just run a long RJ11 cable & plug that straight into the router.
https://www.openreach.co.uk/orpg/home/helpandsupport/how-toguides/howtoguides/downloads/NTE5C_Instru...
Message 7 of 15
Hi
Thanks for the reply. I intend to route the cable through the roof space to an external wall through the wall to a wall socket. Then a short rj11 cable to the modem. Will that be ok
Regards Roger
Message 8 of 15
If this is an xDSL modem to router connection, then you'll normally be better off leaving the modem near the master socket and using a long ethernet cable.  I'm a big fan of flat ethernet cables where suitable, they're easy to hide and reliable!
Whole house, garden, garage and half the street covered by a Flint 4 - WiFi 7 router
Anonymous
Not applicable
Message 9 of 15
@rbbrown2448
That would be fine as would @Crimliar's suggestion. But before doing either, it may be worth trying a pair of powerline adapters to extend ethernet across the mains. Just buy from somewhere with an easy returns policy if they don't work out, but if they do it will save all that faff.
Again assuming you don't need a wired phone in there.
Message 10 of 15
I rather suspect the OP is using the term 'modem' rather loosely and probably does in fact mean BT hub or other modem/router. In which case neither Ethernet solutions will work.
