Message 1 of 2
FTP not connecting - 'too many connections'
I'm having difficulty in regular uploading of my weather station's data to the server. Problem is solved by restarting BT Hub, but this lasts only for an hour or two.
Did BT change anything last week? The problem started Saturday 14th January.
Does anyone know a fix?
Thanks - note I am not web tech savvy.
John
1 REPLY 1
Message 2 of 2
Re: FTP not connecting - 'too many connections'
Hi @JohnDora I don't think this sounds like a BT network issue. Just as a precaution it mightn't do any harm to do a factory reset on the Hub to see if that helps.
Neil
