Message 1 of 15
FTTP 900 suitability with Home Hub 6 (Smart Hub 1) FTTP
Hi,
I am upgrading from FTTC to FTTP 900 soon.
I like my Smart Hub 1 (Home Hub 6) because it works well and most importantly allows me to split the 2.4Ghz and 5Ghz Wi-Fi bands.
I have the SI FTTP model which has the 4th ethernet port labelled in red as WAN.
I intend to keep this router and when BT present the fibre to the ONT , I will then remove the RJ11 from it which is currently doing FTTC and switch over to an ethernet cable in port 4 (WAN) which goes to the ONT.
Few questions if I may:
1) Does the Smart Hub 1 (HH6) support FTTP 900 OK with regard to throughput ?
2) Does removing the RJ11 cable and plugging the ONT into the WAN port switchover seamlessly ? I assume the HH may just need a reboot ?
Thank you and hope this makes sense.
Si.
14 REPLIES 14
Message 2 of 15
Re: FTTP 900 suitability with Home Hub 6 (Smart Hub 1) FTTP
@pezzer1  I assume you do not require a phone service?
Apart from that, you should be fine.
Message 3 of 15
Thanks Keith, no I don't need a phone service.
Message 4 of 15
Keith, I have recently changed from FTTC to FTTP using the new smart hub 2 supplied. However, really fed up that so many devices cannot connect to each other due to the inability to split 2.4 and 5ghz. I want to go back to BT smart hub 1 but the firmware doesn’t have the FTTP option in advanced settings. How can I update the firmware on the smart hub 1 please? Thanks.
Message 5 of 15
As I posted on your own thread firmware updates are automatic so you can't get the FTTP option on your sh1
Message 6 of 15
Just to report back that I had the upgrade to FTTP 900 last week, and the Home Hub 6 (Smart Hub 1) FTTP model has been fine. Speeds have been, as expected, 900/110. Great, in my environment, to have been able to keep the split Wi-Fi bands.
Message 7 of 15
@Clarkey7 the inability to split the WiFi bands has no impact on devices on different bands being able to connect to each other.
Message 8 of 15
If only that were true! Sorry liquorice I have had all sorts of trouble because of it!
Message 9 of 15
Perhaps, but most people including myself, have no difficulty with devices connected to different bands communicating with each other.
Message 10 of 15
@Clarkey7
it is obvious from some forum posts that a few customers seem to have problems with the 2.4/5ghz having same SSID but I, like @licquorice, don't have any problems with the combined wifi bands
