Message 1 of 6
FTTP IPv6 UniFi Dream Machine Pro
I have my Dream Machine Pro connected directly to the ONT and am trying to configure IPv6.  I have tried all the settings I can find on this forum and others, on both the LAN and WAN side but don't seem to be having any joy.  If someone has successfully configured this on a Dream Machine I'd love to see a screenshot of the WAN and LAN settings pages so that I can simply copy them across, I'm worried that I'm missing something small in the settings somewhere which is causing me a problem!  I am on Network version 7.4.162
Thanks in Advance!
Luke
Tags (3)
5 REPLIES 5
Message 2 of 6
Re: FTTP IPv6 UniFi Dream Machine Pro
While I don't have the UnifI Dream Machine Pro, the settings for the WAN should be pretty simple.
Connection type:  Native
Interface: PPP
DHCP-PD (or DHCP64): enabled
WAN Prefix length: 56
Auto-Config:  Stateless will generate random IPv6 addresses within your allocation while stateful will use a smaller number of (near) sequential IPv6 addresses.  That really ought to be about it!
Are you getting any specific errors in the logs after making the settings?
Whole house, garden, garage and half the street covered by a Flint 4 - WiFi 7 router
Message 3 of 6
@Lukehakes I cannot find the original post by @eightace  but here is how they fixed my lack of UDM IPV6 support (instructions below) . I was so pleased it fixed the problem I took a screen shot of the instructions for future reference which I have detailed below. I'm using a UDM with Network 7.4.162
Internet - WAN networks - IPV6 using DHCPv6 - prefix delegation 56
Networks - local networks - LAN - IPV6 interface type - prefix delegation and IPV6 RA on and DHCPv6/RDNSS DNS Control Auto
I just retested on my UDM and it still works.
I hope it helps and works with the UDM Pro!
Message 4 of 6
Hi,
Yep, those are the settings I am using.  Just doesn't seem to work when I test on https://test-ipv6.com/ just get a bunch of fails.  Assume that site works for you?
Cheers
Message 5 of 6
Try a couple of the other IPv6 test sites.  Especially if you are running a dual-stack some of the IPv6 test sites tend to give a number of false negatives.
On a dual-stack setup, running the Chrome Extension "IPvFoo" can be interesting as you can see how much of a particular site is IPv6 vs IPv4!
Message 6 of 6
@Lukehakes Yes, https://test-ipv6.com/ scores 10/10 in the tests. It did take a minute or two after the changes to give this result though.
