Message 11 of 16
Re: FTTP New build ethernet ports
Ok mate,  appreciate the reply..  ill have to get this sorted, its always something isn't it.. it couldn't of just worked! Haha
Message 12 of 16
@licquoriceI'm glad you said that.  The last time I said it I upset someone...so I was keeping quiet.
@LowPingHunterRunning cables under carpets is a bad idea.
Message 13 of 16
Would take more than that to upset me haha..  but already knew it was my responsibility, I'm basically trying to find out what I can do to fix it..
And no problems in last couple houses doing it mate, flat cable under the carpet, works a dream
Message 14 of 16
If you are having trouble finding someone to check out the Ethernet ports you may want to try asking in your local PC shop as they should have the contacts (if not the personnel) that can check it over and fix it.
Message 15 of 16
You mentioned it's a new build - if you bought it directly from the developer then that would be my first port of call to try and get the cabling fixed.
Anonymous
Not applicable
Message 16 of 16
When you moved the SH2 into your bedroom, how was it connected to the ONT? If you were still using the patch panel & the connection was stable, that would seem to rule that out.
