Message 1 of 3
Sonos Beam Gen 2
So I've a Sonos set up, a set up that requires a 2.4ghz band to connect.. I figured it would be ok, since hub2 is dual, but for the life of me and can't get my app to pair.. i even tried disabling 5ghz until I connected, but even them.. just won't play ball.. has anybody else had this issue with BT and Sonos? Hate the idea of my £1000+ set up, being effected by a router.
2 REPLIES 2
Message 2 of 3
Re: Sonos Beam Gen 2
Have you tried changing the 2.4GHz channel with the 5GHz turned off?  Others have reported some success with this.
Message 3 of 3
I shall try this tonight.. appreciate the reply.
