Message 1 of 3
Fifa 22
Hi, help needed
For the last three to four weeks ,I am experiencing delay when playing Fifa 22 on the xbox series x
There is a delay when trying to pass, shoot or just control the ball my player seem like they are stuck in mud
I am running on a 1gb connection with a 100mb upload speed. When playing I get between 8 to 14ms connection.
I have opened  the required ports and have a static IP.
Does anyone  know what else I can do to fix these issues , is there an issue with the hub?
Any help would be appreciated
2 REPLIES 2
Message 2 of 3
Re: Fifa 22
How is your Xbox connected to the hub because I have a 130mbps FTTC connection and my online gaming is rock solid. I have a PS5 connected by Ethernet and Smart Set-up and parental controls are off.
Message 3 of 3
Re: Fifa 22
Xbox is connected via either cat 6 or cat 7 Ethernet cable (tried both)
I have also tried changing the dns , but haven’t seen any improvements with that either
the router is a smart hub 2 , so according to other posts the smart setup has been removed in the last firmware update and parental controls are disabled
