Message 11 of 16
Re: Halo black discs - lost mesh?
It is confusing, it would help if they gave their different equipment models simple names for reference. 😅
It's the second one I have (complete wifi).
Message 12 of 16
The reason I asked was because in your first post you said " the "whole home wifi" app stopped working with my equipment", The Complete Wi-Fi discs should be configured using the My BT app not the WholeHome WiFi app.
Message 13 of 16
Weirdly, the app actually took me through setup to start with.
I guess that was just an anomaly, I've deleted the app now I know it's the wrong one. 😅
Do you know if the discs I have are mesh? I get the impression they're a mystery. 🥴
Message 14 of 16
As far as I am aware, they do form a mesh but I've never really looked into it and can't be sure
Message 15 of 16
Message 16 of 16
Its quite straightforward, both are mesh systems, Whole Home (white discs) are able to be used with any ISP or router and form their own mesh independently of the router. Complete WiFi (black discs) can only be used with the BT Smart Hub2 which integrates as part of the mesh with the discs.
