Message 1 of 4
Halo disc not connecting in metal shed
trying to extend my wifi by placing a Halo Disc in a metal shed in the garden and it won't connect.  Is it likely to be the metal that's prevent access?
tia
3 REPLIES 3
Message 2 of 4
Re: Halo disc not connecting in metal shed
I expect the metal shed is acting like a faraday cage and blocking the wifi signal
Message 3 of 4
tia
Yes plus it will also depend how far the shed is from the BT Hub. If there is a window in the shed place the disc beside the window and it might be able to get a signal.
Anonymous
Not applicable
Message 4 of 4
Regardless of the metal shed, it's a common misconception to think you can place a mesh/extender where the signal is weak. You have to either place them at the edge of the router's range where there is still  a reasonable signal, so that they can "relay" that signal, or hard wire by ethernet.
