Message 1 of 5
Hikvision NVR Goes Offline
Could anyone please advise where I am going wrong, with the BT broadband connections for the Hikvision NVR's?
I have tried every combination of numbers advised in the NVR network setup, I now think the issue is with the BT hub. I have used the NVR on another fibre supplier, and using a Netgear router, and that worked fine.
The problem is, the system will work fine for a few hours, and then the Hikvision platform access will go offline. That's the platform I am using for remote access. I have setup DDNS with No-Ip as I have for many years, and again that works fine. when the NVR goes offline, DDNS connection is also lost.
I have set the IP as static, and the preferred DNS to 192.168.1.254. I have also tried many other combination of numbers there, 8.8.8.8, 8.8.4.4, 1.1.1.1, but still the system goes offline.
Could anyone please advise if there is a setting in the hub, or if BT block this access at all?
Many thanks in advance
4 REPLIES 4
Message 2 of 5
Re: Hikvision NVR Goes Offline
@CCTVuser
Have you set up port forwarding for the NVR?
And the DDNS is that set up in the hub or the NVR?
Message 3 of 5
We have a Hikvision 2 camera 4k system installed in 2015......
No sooner it was up and running we encountered issues with it going offline after a period of time. Found out the BT supplied router was overheating where it hadn't before, needing a reboot to restore the connection.
Ended up swapping out for a Draytek 2860ac router, no issues since.
Message 4 of 5
Thank you for your reply.
Yes all that’s set up and works correctly. I also know it’s not the NVR, as the recorder was set up on another none BT network. The issue has started when connected to a BT hub 6, and this I’m 99% certain is the issue.
I originally set up with a Netgear hub, and it worked fine.
After digging around today, and contacting BT tech line (they had no idea whatsoever about anything I asked about) However I did speak to one very knowledgeable person from a CCTV supplier, and he thinks it could be IPVR6 related.
Anyone know how to disable that on the hub, as I have tried,  it will not disable?
The issue I have, BT are the line supplier, and they cannot give help, why am I paying for a service that has a tech team that can’t solve the problem with their equipment?
Message 5 of 5
Anyone have an idea please?
Perhaps BT could answer the question about their system not working?
