Message 1 of 7
Home Hob Access
Can someone please explain how to get access to the HomeHub because both  Google and Edge are not connecting  saying it an insecure site.I have tried going off line but that didn't work.
6 REPLIES 6
Anonymous
Not applicable
Message 2 of 7
Re: Home Hob Access
Just ignore the warnings as they're not relevant.
Message 3 of 7
Re: Home Hob Access
192.168.1.254
Works for me
Message 4 of 7
Re: Home Hob Access
The browsers say its insecure because it is not HTTPS however that does not matter because the hubs management pages can only be accessed from your own LAN (network) and not from the Internet.
When you get the warning just ignore it, there will be a link somewhere on the webpage to allow you to go to the management page.
Alternatively when you try and go to the management page on the Edge browser. Locate the lock icon on the address bar and click on it. From the drop-down list, select “Permissions for this site”. Scroll down and find “Insecure content.” Click its drop-down list to change “Block (default)” to “Allow”.
Message 5 of 7
Re: Home Hob Access
Hi ,Thanks for the solution,but I have tried all you suggested and zilch.
But,I did go onto Chrome in my Chromebook and for this19216811.uno/bt-hub-manager/ and it works.So i went back to Edge and Chrome on my laptop,got the web page ok and a place to log into manager but got back to zilch again.
So I,ve given up and will have to use Chromebook to manage the hub.
Thanks again
Message 6 of 7
Re: Home Hob Access
The problem is with your browsers, not BT.
In Edge try logging on with this link
Home (bthomehub.home)
When the page comes up with the insecure site message,
click on the "Advance" button. This should open a new page shown below. Click on the "continue to BTHomehub Home" link.
Message 7 of 7
Re: Home Hob Access
Hello again,
If these are screen prints off Edge I don,t recognise them.Used your link but nothing.
I do appreciate that this is not a BT problem but thought someone may have  a solution .
Again thanks for help but I'm closing this and relying on my Chromebook
Bye
