Message 11 of 12
Re: Home Hub 3 & Battery Back Up - Incompatible power connection
I had same issue.  After several attempts to get BT agents on the phone to understand the issue i gave up with them.   Then I went onto the EE website and bought this for £9.99 which is exactly the solution. Fitted and working.
https://ee.co.uk/products/battery-back-up-plus-connecter-cable-for-smart-hub-3-cable-only
Message 12 of 12
Both BT and EE are out of stock of the Battery Back Up Plus connecter cable for Smart Hub 3 (cable only).  No indication of when they will be re stocked. Not good as with the Digital Home Phone roll out lots will be required
