Message 1 of 9
How do I stop my router being a wi-fi hotspot?
I have an unknown device connecting to my Wi-fi.
Switching Wi-fi off, for several minutes, then restarting doesn't remove it.
It's not my mobile.  What is it?
BT Smart Hub Manager will not allow me to remove it - Red Circle with Diagonal when I hover the cursor over the Remove 'button'.
Any help welcome.
8 REPLIES 8
Message 2 of 9
Re: How do I stop my router being a wi-fi hotspot?
Do you any Sky devices as the MAC would appear to be for one.
Message 3 of 9
Try looking up the vendor of the MAC address
http://www.coffer.com/mac_find/
Anonymous
Not applicable
Message 4 of 9
It could  well be your mobile or another device set to use MAC randomisation, which most are by default. That means each time the device connects, it uses a phantom MAC address rather than the real one. Then next time it connects it uses a different one & the last one becomes orphaned as an unknown device. Only a factory reset will clear them together with turning off the feature on each device for your home network.
Message 5 of 9
Def not mobile (not smart). Powered both phone and router off, then restarted router, leaving phone off. Still on wi-fi.
Thanks for suggestion.
Message 6 of 9
Tried link - Said couldn't find D4DACDDC1282 or D4DACD
Message 7 of 9
Switched off SKYQ, and Humax, boxes at mains. Then switched off router wi-fi. Restarted router. Device still there, but Humax (game console) had gone.
Thanks for the suggestion
Message 8 of 9
As @gg30340 said earlier, it's a Sky device.
Whatever device it is, it has your WiFi password.
Change your WiFi password and see what doesn't connect.
Deleting a device from the network map doesn't do anything except remove a non-connected entry from the list.
Message 9 of 9
Thank you will try that.
