Message 1 of 4
How to disable BT/EE mini hub internet filter.
My wired Broadband has broken, and BT promise a fix by Friday 23 by 18:00.
Mind you, the fix date/time has steadily receded since Monday 19th... Anyway, I'm using an EE/BT Mini hub in the meantime. The mobile connection varies, and drops out quite frequently, (EE coverage in SG1 being a bit iffy). But how do I disable internet filtering through this device? It's turned off for wired broadband via MyBT, but I can't see anything relevant either there, or on the hub itself... What am I missing?
TIA
3 REPLIES 3
Message 2 of 4
Re: How to disable BT/EE mini hub internet filter.
Hi @tware6671,
I hope your connection is fixed today. I am sorry that it hasn't been yet.
Take a look at the BT 4G Mini Hub Parental Controls guide.
That should show you how you can change the settings.
DanielS
Message 3 of 4
Thanks!!
Message 4 of 4
You are very welcome @tware6671,
Have a great day
DanielS
