Message 1 of 4
How to separate incoming and outgoing connection
How do I separate the incoming connection/signal to the outgoing connection/signal?
as a gamer I feel as there is an imbalance when playing online games so I wonder if it’s possible to split the 2 as there are 2 wires that the connection comes in on?
thanks
3 REPLIES 3
Message 2 of 4
Re: How to separate incoming and outgoing connection
@Daniel92
It does not work that way. Broadband uses both wires to establish a connection. Internet traffic is passed in both directions over that connection.
The service is asynchronous, and priority is normally given to the download path.
Message 3 of 4
as priority is 'normal' given to download path, how do you prioritise the upload path instead of download path?
thanks
Message 4 of 4
You would need to that in your router. The BT Home Hub does not have that ability.
On a VDSL connection, more usable frequency bandwidth is allocated for download usage, so there is a limit to what you could achieve on a router using QOS (Quality Of Service) controls as you cannot alter the way that upload data is handled over the BT core network.
