Message 1 of 2
How to setup BQM on BT Smart Hub 2
ive set up a BQM on thinkbroadbands website but my BQM is all red . Its worked with other providers but not with my BT , i suspect something on the BT Smarthub 2 is blocking the BQM monitor but i cant figure what setting i need to turn on or off on the router
1 REPLY 1
Anonymous
Not applicable
Message 2 of 2
Re: How to setup BQM on BT Smart Hub 2
The BQM requires the router to respond to pings. Unfortunately BT Hubs can't do that.
Although this post suggests to can put another device that will respond in a DMZ.
