Message 1 of 10
How to tranfer port forwarding settings to new hub?
I have a problem with my existing Smart Hub 2, which needs replacing.
How can I transfer configuration, specifically port forwarding, to the new hub?
9 REPLIES 9
Message 2 of 10
Re: How to tranfer port forwarding settings to new hub?
You can not. You will need to set them up again.
Message 3 of 10
Is there a way that I can at least save and/or print out the existing port forward info to make it easier to enter the details again?
Message 4 of 10
Take a screenshot. Print screen.
Anonymous
Not applicable
Message 5 of 10
@Daveiw100
Most browsers have a screenshot facility or there's Microsoft's Snipping Tool.
Message 6 of 10
I can take screenshots, but these cover many pages. Is there a way to print the details?
Message 7 of 10
However many port forwarding settings do you have to have multiple pages?
Message 8 of 10
Google is your friend but to save you the effort of looking how to do it, take the screen shot then open a word document and paste the screen shot into the document then press print.
Message 9 of 10
just done screenshots of the configuration
just thought there may be an easy way to transfer the config from one device to another, but, alas, that is not the case
thanks all for your help
Message 10 of 10
You can make a backup of the hub and restore it but it is not transferable to another hub.
