Message 1 of 310
New hub keeps losing wifi connections, even though blue lights lit
Not sure where the other post I submitted this morning went, so trying again. Was provided with new hub ready for DV & was switched over on 14/02. While the lights on the hub are always blue, it keeps 'losing' my wifi-connected equipment, i.e. laptop, printer, mobile & landline. The only way to get them back is to switch off the hub & switch it back on again. This is happening more than once a day & is becoming frustrating! While I don't use the landline for outgoing calls, I do get occasional incoming calls & the only way to make sure it's working is to phone my landline number from my mobile with its wifi switched on, after which the landline works again. I'm sure I shouldn't need to keep resetting the hub to get wifi on other equipment, but I can't seem to find out how to talk to a human at BT; all I end up with is a text for 'virtual help' which my provider would charge me for if I used it.
Anybody got any suggestions? All my equipment is near the hub (furthest away is my laptop, which is only 2.2m away!).
309 REPLIES 309
Message 2 of 310
Re: New hub keeps losing wifi connections, even though blue lights lit
change the new SH2 SSID to that of the existing hub and then change SH2 hub wifi password to same as old hub and then see if devices connect without any problem
Message 3 of 310
@imjolly
I have absolutely no idea what that means, e.g. what is an SSID. Can you explain in simple language to me as I am not (and don't have time to be) tech-savvy!  Sorry 😕
Message 4 of 310
SSID is the 'name' of your hub which you connect your wifi to
so go to 192.168.1.254 into a web browser (not google search) and then enter admin password form back of new hub.  you now need to change the name (SSID) of the new hub to the name (SSID) of previous hub and also change wifi  password to that of previous hubs and when done that save.
your devices should now connect to new SH2 as if it was the existing hub before the change
Message 5 of 310
@imjolly  Thanks, that makes sense, but I can't do it as I no longer have the old hub so I don't know what it was called, nor do I still have its password.
I'll just have to keep trying to speak to a human at BT. Sigh.
Message 6 of 310
It’s not clear from what you’ve said whether you are having problems with Wi-Fi stability or with the Digital Voice.  (They are separate things.  DV does not use Wi-Fi, although it can use DECT with cordless phones).
If it is the Wi-Fi, as imjolly says, you may have to reset the wireless name and password but if your equipment is connecting and then dropping it suggests that is not the problem.  (It would not connect at all if it didn’t recognise the name and password).
If it is connecting to Wi-Fi but not remaining stable it suggests interference due to the channel in use having changed.  Going into the wireless settings and experimenting with changing the channels may help.  (Your other devices will adjust automatically, so you don’t need to touch them).
There have also been instances of the 5GHz preventing 2.4GHz devices connecting properly.  Turning off the 5GHz until all the devices have connected and then turning it back on again usually fixes this.
If the problem is with DV, have you rebooted the hub?  It doesn't seem to configure properly until it is rebooted (and the paperwork doesn't mention that anywhere).
Message 7 of 310
@WSH  Thanks.
If it is connecting to Wi-Fi but not remaining stable it suggests interference due to the channel in use having changed.  Going into the wireless settings and experimenting with changing the channels may help.  (Your other devices will adjust automatically, so you don’t need to touch them).  How/where/what?!
There have also been instances of the 5GHz preventing 2.4GHz devices connecting properly.  Turning off the 5GHz until all the devices have connected and then turning it back on again usually fixes this. Again how/where/what?!
If the problem is with DV, have you rebooted the hub?  I assume you mean the phone? It does work except when the hub 'loses' every piece of kit it's supposed to be connect to. I've had to reboot the hub a lot - see original post. It doesn't seem to configure properly until it is rebooted (and the paperwork doesn't mention that anywhere). There was no paperwork with the new hub.
Message 8 of 310
If you connect to the Smart Hub using a browser and enter the IP address 192.168.1.254 in the address bar, you should see a management page with your phone number displayed and next to it a big panel for Wireless.  Go into that and it should be fairly intuitive from there.  Select a different channel and save.  The 5GHz settings are in the same place. You will need the admin password off the card on the back to make the changes.
No, I mean the Smart Hub.  Your post suggested you had restarted the phone, not the hub.  If you have and it didn’t fix it, then it suggests the problem is with the Wi-Fi as above.  “Paperwork” was a euphemism.  Who does actual paperwork today?
Message 9 of 310
Thank you. I have managed to have a web chat with BT & an engineer is coming this Thursday to hopefully sort out the problem.
Message 10 of 310
Good.
Let us know how you get on.
