Message 1 of 2
Hub 6A showing very brief but very frequent "The LAN DHCP Server is inactive"
Can I ask if this is a know issue? I don't remember seeing this before.
My Hub is on firmware SG4B1000E079 updated on 20-May-2022.
Wondering if related to firmware update?
Tried a factory reset but no change.
An example from the event log is shown below.
TIA.
12:20:16, 03 Jul. :The LAN DHCP Server is active
12:20:16, 03 Jul. :The LAN DHCP Server is inactive
12:18:16, 03 Jul. :The LAN DHCP Server is active
12:18:16, 03 Jul. :The LAN DHCP Server is inactive
12:18:06, 03 Jul. :The LAN DHCP Server is active
12:18:06, 03 Jul. :The LAN DHCP Server is inactive
12:15:50, 03 Jul. :The LAN DHCP Server is active
12:15:50, 03 Jul. :The LAN DHCP Server is inactive
12:15:34, 03 Jul. :The LAN DHCP Server is active
12:15:34, 03 Jul. :The LAN DHCP Server is inactive
12:15:23, 03 Jul. :The LAN DHCP Server is active
12:15:23, 03 Jul. :The LAN DHCP Server is inactive
1 REPLY 1
Message 2 of 2
Re: Hub 6A showing very brief but very frequent "The LAN DHCP Server is inactive"
Having investigated this further, it seems to be caused by an IP camera. If I depower the camera the issue stops.
I have checked that DHCP is turned off on the camera.
As far as I am aware this is not causing any problems on my network, but I am interested as to why this is happening?
