Message 1 of 15
BT Full fiber 900MBs
Hello, I'm wondering if someone can give me some guidance.
I recently upgraded to full fiber 900, everything got fitted fine. But, no matter if I'm right next to the hub or 1 meter away, it still says, on the wifi signal checker that my signal is low. Only showing 2 bars and could be stronger. As requested by the app I did diagnostics and it discovered a fault. I had the hub refresh the wifi several times but to no avail. I contacted BT and they said the connection from the line to the hub is perfectly fine as it should be. But I still have this issue.
Thank you in advance.
14 REPLIES 14
Message 2 of 15
Re: BT Full fiber 900MBsw
I would log a call and get the SH2 replaced. I find it’s wireless performance poor and unreliable and I suspect firmware issues for the latter but in your case it sounds more fundamental.
Message 3 of 15
Hi mate thanks for the reply, I already have another SH2 from my last package 4 days ago, just tried it with that and I got 2 excellent connections, did the same test 5 minutes later in the same location and it went back to poor. Am I best just ringing and try and explain to them?
Message 4 of 15
Have you turned off smart setup?
Message 5 of 15
Nope as smart setup is no longer on SH2
Message 6 of 15
I don’t use the SH2 but can you manually select Wi-Fi channel?
If you like a post, or want to say thanks for a helpful answer, please click on the Ratings icon. If someone answers your question correctly please let other members know by clicking on ’Mark as Accepted solution’
Message 7 of 15
Yeah the here they are
Message 8 of 15
I would download a Wi-Fi inspector app to see if there is a possibility of co-channel interference from another device.
Message 9 of 15
Try switching off 5g and manually selecting another 2.4g channel. If there are “radio modes” available try mode 2.
Obviously change one thing at a time to isolate the issue.
Message 10 of 15
Checked the network for the channels and everything seems alright.
Also tried changing modes, thinking of asking for another new SH2 Maybe it'll fix things.
