Anonymous
Not applicable
Message 11 of 16
Re: Hub Manager Access and VoIP
Message 12 of 16
If you go to Setting on Opera and select 'Learn More' on the Clear browser data tab and go to to Security and Privacy - that is what it says.
I allow Opera to update - so unless the Help on Opera is incorrect all I can assume is that it clearing browser data also clears password and log-in data as I have indicated.
Message 13 of 16
@Anonymous  You don't need a password to access the hub manager, only if you need advanced options.
@Bobg1  As @imjolly  says, the hub manager is HTTP not HTTPS
I still think its worth resetting your network adaptor. Go to Control Panel> Network and Internet > Network Connections. Select your Network adaptor  and disable then enable.
Message 14 of 16
Will a disable / re-enable just load previous setting, rather than reboot from scratch and thus create new settings??
Message 15 of 16
It will flush any dynamic settings and allow the NIC to obtain correct settings.
Did your previous hub have a different IP addressing scheme?
Message 16 of 16
Sadly no change, still to access. Disabled /Enabled via Device Manager / Network adapter.
I am not aware the previous hub had a different IP addressing scheme. It automatically set itself up when I connected it without any issues.
