Message 1 of 5
Hub Manager
I'm trying to get into the Homehub manager.  We wish to change our wifi password,  however on typing in 192.168.1.254 as suggested on the website, it doesn't open Homehub manager, it just initiates a Google search.  There used to be an address like homehub.home or something like that.  Any ideas?
4 REPLIES 4
Message 2 of 5
Re: Hub Manager
you need to type 192.168.1.254 into address bar not search
Message 3 of 5
Re: Hub Manager
The 192.168.1.254 should work however try this http://bthomehub.home/
Learn about the BT Hub Manager | BT Help
Message 4 of 5
Re: Hub Manager
It was in the address bar, but Chrome still initiates a search. Edge did too.
Message 5 of 5
Re: Hub Manager
Thank you, this is just what I needed.
