Message 1 of 5
I have set up
Hi
I am having difficulty with ny WiFi connection it will not fully connect I had called and tried to get an engineer out ot turns blue then orange on the hub? Could I please have help
4 REPLIES 4
Message 2 of 5
Re: I have set up
is your hub connected to something like this  and if so are lights green
or like this
Message 3 of 5
Re: I have set up
I do have this but it's not powering up I think I need openreach out
Message 4 of 5
Re: I have set up
Check the power supply on the ONT (white box with green lights) is pushed in to the bottom properly, and there may be an on/off button there as well. (In is on).
Message 5 of 5
Re: I have set up
Are there any lights showing?
As posted by @tonysmini018  `you need to check that pwer cable is pushed right home and it is switched on
