Message 1 of 6
IP Address not accessible
For some reason I'm not able to access a server on 192.168.1.253
The router/home network is 192.168.1.0/24
DHCP pool is 192.168.1.64 - 253
The servers IP (and subnet) is static, ie.not assigned by the hub.
I realise the address is inside the DHCP lease pool, but it's not assigned to anything. It's there any reason I should not be able to access it?
Any help would be really appreciated!
5 REPLIES 5
Anonymous
Not applicable
Message 2 of 6
Re: IP Address not accessible
Don't understand this, do you mean you've changed the address of the Hub? If so I'm not sure 0 is a valid address.
Obvious things to try are limiting the DHCP pool to 250 or changing the server address to below 64.
Message 3 of 6
Probably no consolation, but I have given a device an address of 192.168.1.253 in the past with no problems without changing the DHCP pool.
@Anonymous that is the correct way to describe the OP's subnet.
Anonymous
Not applicable
Message 4 of 6
@licquorice
I understand the /24 notation being a binary representation of 255.255.255.0 subnet but not the 192.168.1.0 IP address?
Message 5 of 6
It's just the start address of the subnet, and is a valid address in itself.
Message 6 of 6
Has the server previously used any other IP address?
Try IPconfig /release, IPconfig /flushdns and IPconfig /renew
