Message 21 of 28
Re: IPTV settings on ER605
@licquorice
Another thought, my understanding is that PIM is not a protocol, it is a broadcast of packets without a protocol (such asPPoE).
It could be that the TP-Link software defines a PPoE interface very tightly, so excludes any UDP packets outside of that encapsulation. Other router software may take a different approach.
This is way outside my experience or knowledge, I’m just happy to have it working 😉
cheers
Message 22 of 28
Hello, apologies for bumping an old thread and thanks to everyone who contributed with useful information.
I will need to replace a Homehub with a DrayTek router and will need to have the IP TV service working, I'm trying to figure out what's required before making the change.
@mhoamwhen you say in message 15
...hence the need for a Router capable of handling two connections from the ONT
...do you mean two physical Ethernet links (2 x patch leads from the ONT to the router)? Many ONTs I have seen only have one port (this one may have more, I haven't had it installed yet).
Message 23 of 28
HI @1550
No, My router (ER605) does support multiple WAN ports for different (fallback) inbound networks but I use only one connection from the OpenReach ONT to the WAN port on my router. As you say, most ONTs only have one physical connection.
However, my router does allow you to define two logical interfaces on the single WAN port, the main one is for the PPoE connection to the BT network for the normal traffic, the other is a secondary interface with a  static 10.10.x.x address which picks up the Multicast packets used for the BT TV channels.
I've no idea whether DrayTek routers support such a secondary logical interface on the main WAN port for MultiCast packets. Also with the sale of BT Sport to TNT I do wonder how long BT TV will survive in its current form. I know some of the TNT sports channels are "broadcast" over BT TV but only their streaming app provides the full TNT offering.
Good Luck
Message 24 of 28
@mhoamthanks for the info and the fast reply.
As far as I can see, DrayTek routers only support multi-PVC on the xDSL WAN ports  and not on the Ethernet WAN. So I might have to find a different way of getting this to work. Basically a PBX with SIP trunks will be on the LAN so I need to open port 5060 but lock it down to the SIP trunk provider's IP ranges. I don't believe the Homehub has that capability.
BTW if you want to view dead links in future you could try using the wonderful Wayback Machine, the link in your OP is archived there https://web.archive.org/web/20200805182707/https://community.bt.com/t5/Archive-Staging/Using-a-3rd-p...
Message 25 of 28
Any advice on how to do this on OPNsense?
Message 26 of 28
Hi @mhoam
I have recently moved from a Ubiquity Edge Router X as it kept having DHCP issues and I am experiencing the same issues you did with IPTV and the ER605 router.
I have tried your solution but the router didn't create a route for the PIM packets and it caused the PPPoE connection to drop.
I tried creating a static route for the IPTV multicast packets but this didn't work either. I can watch catchup TV but not any of the live channels. I am quite new to networking so not sure my rules are set correctly. Any help on this would be hugely appreciated.
Message 27 of 28
Hi @jj1977
I had this problem some years ago with an ASUS VDSL modem router. I realise that FTTP use a BT modem and separate router, so the teminology and capabilities of your router may not be the same, but have a look at the link below as it may give you some pointers as to what to look for in your router's setup.
The setup of a PVC (permanent virtual circuit) is the equivalent of the second (logical) connection referred to by @mhoam in the posts above.
How to setup IPTV for UK BT YouView/TalkTalk VDSL on DSL-AC68U
Message 28 of 28
So i have been struggling with this as well. but i got a work around.
On the ER605, PPPoE is the default connection set up for BT broadband. If you scroll down to the advance setting however, you can also add a static IP (192.168.x.x) with a subnet mask of 255.255.255.0 and save settings.
From there go to settings ACL Gateway rules and create 2 rules, first one, Name Multicast - Direction - WAN IN - Permit - UDP - PIM.
Scroll down to Source, Type - IP Group. Then create new IP Group by clicking the +create, name it WAN Static and in the IP Subnet add you BT internet facing IP. (you can find this by going into the ER605 router and looking at the WAN port connection) and save.  Then select both the WAN 1 and WAN Static as the source.
Then go to destination, Type - IP Group, then create a new IP Group with the subnet IP of the VLAN your IPTV is on and save, then select it as the destination.
Second ACL rule, Name - IPTV - Direction - LAN --> LAN - Permit - UDP - PIM.
Source - Type - Network - Default VLAN or the VLAN receiving you incoming connection.   Destination - Type - Network - your IPTV VLAN and save.
Then go to Switch ACLs and create new rule. Name - Multicast - Source - Network. Then select you default VLAN or the VLAN caring all Tagged VLANs. Destination - Network - select your IPTV VLAN.
This should get you live TV across the internet to your BT/EE TV Box. This is what has worked for me.
Hope this helps.
Tags (1)
