Message 1 of 8
Intermitent Wifi and Slow Speeds
Hi Everyone,
First off I have an account under "RobCharles1981" but I forgot my password and the password reset link doesn't work and I even checked in my junk mail folder but nothing ends up there so that's why I made a new account.
Anyway, I need a bit of insight in whats going on here.
Well basically, I've recently moved house and my sister got me BT Full Fiber on the EE network via Wi-Fi and I should be getting lightening fast speeds with this service
But at the moment its total pants:
10meg Download and almost 29 meg upload
When I arrived in my new place in the last week, I had a "Smart Hybrid Router" connected into a BT Modem and couldn't establish a connection it was like waiting for a bus.  The BT Modem was located down stairs and my Computer is upstairs.
The thing is after we spoken to BT they said I needed to use my BT Smart Hub 2 which was back in my old place (doh!) so back down I go on a near 3 hr round trip, connected to wifi the the speeds where just unusable.  Or they sent me a new hub which I received like yesterday, and the speeds are still worst!  Together the Smart Hub 2 and BT Modem is located downstairs
I reached out on live chat who are useless to say the least.
And I thought sod it Ile do some investigation first before calling BT, I have onboard wi-fi and it seamed that playing with the antenna seamed to give it wi-fi signal and sometimes not, I also brought a Wi-Fi card  to test which took a few moments to get a connection.
But latterly I'm having BT to come to the house to investigate this issue and I'm wondering really in the first instance on what this problem is?
I look forward to hearing your thoughts
Cheers
Rob
Cheers
Rob
7 REPLIES 7
Message 2 of 8
Re: Intermitent Wifi and Slow Speeds
Hi @Welshman1981
Welcome back to the Community!
What speeds do you get if you connect your computer directly to the hub via ethernet cable?
Are you able to perform a speed test using an alternative device connected to the Wi-Fi, such as a mobile phone, while you're in the same room as the hub?
Ali
Message 3 of 8
Well the BT Guy came yesterday and plugged his laptop directly into my hub and the speeds where off the scale!
To sum it up he said  to get a couple of "Wi-Fi" booster disks to help with the problem.
Called up BT and they sent me a couple, annoyingly Royal Mail attempted delivery this morning when we where in! - So I'm gonna head over there to the Delivery office to pick up the package!
Message 4 of 8
@Welshman1981
Great to hear the engineer test confirmed the internet speeds were as they should be. I suspected it may be the Wi-Fi signal distance that was causing the issue.
Just be sure to use the BT app set up service which will help determine the best location for the Wi-Fi discs.
Thanks for keeping us updated!
On a side point, I've let admin know you're having an issue with your password reset email.
Ali
Message 5 of 8
Hiya,
Many thanks for that, what BT app should I looking for?
Cheers
Rob
Message 6 of 8
@Welshman1981
It's just the usual My BT app | Download The BT App | BT.
As soon as you log in it should show you the option that says "improve your Wi-Fi".
Ali
Message 7 of 8
Cheers for that - it seams my sister set up the BT account and I can't access it as yet!
Message 8 of 8
Hi there @Welshman1981
Please let us know how you get on once you can access the BT account 🙂
Leanne.
