Message 1 of 2
Ipv6 question
I play a rather old game, that requires me to disable this for multiplayer purposes. While it is bothersome to toggle on and off for the software.
it would be a lot easier if I could make this an exception to the rule on my hub, just like you can with with port forwarding.
Is there a tutor or any way to toggle the ipv6 in such a way?
Using a smart hub 2
Thanks for reading.
1 REPLY 1
Message 2 of 2
Re: Ipv6 question
No, you can't.
Just disable IPv6 on your laptop/pc.
