Message 1 of 4
Is Fibre 250 FTTC?
Hello everyone,
I've just rented a flat where the landlord forbids drilling holes in the wall (mainly "for those fibre connections") so I believe any kind of FTTP is a big no-no.
I've checked the postcode on BT website and apparently the only options available are:
- Fibre Essential
- Fibre 1
- Fibre 2
- Fibre 100
- Fibre 250
I wonder if the fastest option here - Fibre 250 - is FTTC and uses the copper wires in the house without the need to drill holes?
Also, as a side question, any advice on how to eventually install FTTP in the future? I believe passing the cable through the window might go against standard procedures of OpenReach?
Thank you all!
3 REPLIES 3
Message 2 of 4
Re: Is Fibre 250 FTTC?
Fibre 250 is G.FAST using same connection of copper from cabinet to your home
Message 3 of 4
It MAY also involve drilling as well as there's an openreach modem to be installed
Message 4 of 4
No, the SH2 is G.Fast capable. Even if a modem was needed, drilling wouldn't be required.
