Message 11 of 16
Re: Is it possible to disable remote logins on Smart Hub 2?
Via the Internet IP address.
You guys are giving me the impression that maybe i have a different version of Smart Hub.
How can you tell which version it is? I got it in April of this year.
It's for business, do we get given different Hubs? If so then I still need to find out how to disable the remote acess to the routers web pages.
Message 12 of 16
If you remove the WIFI card details thing on the back it says Smart Hub 2 there.
EE900 | Nokia ONT | Ubiquiti ER-X | EETV Box Pro (IP Mode) | Unifi CK2 | 6x Unifi U6+ | 4x Unifi SAK Ultra
Message 13 of 16
I can now see that it states it's a Smart Hub 3. It's in black lettering on a black router, not on the label.
So how do I disable remote acess to that?
Message 14 of 16
I only mentioned the SH2 writing because I know that it is there.
The SH3 is a business router I think, I dont know anything about that one, the business forums might help, are you a business customer?
Message 15 of 16
It's not ideal but I managed to disable it by setting a port forwarding rule on ports 80 and 443 which forward to an unused internal address and random ports.
Message 16 of 16
In the end I swapped out the BT router for a Drytek Vigor 2862. Works a treat and far more configurable.
