Message 1 of 6
Issues and help on Halo and SMART wifi
Hi ,
Just moved over from Fire 2 to Halo 3+ - Smart WIFI Disk and Hybrid conncet was also sent both are EE .
1) Setting up the EE SMART WIFI is easy , with wps . but my worry is that when it is connected I can see the wifi network as EE wifi/Not secured ? which is bothering me , I have tied to access via GUI and other methods to see if I can add a Password- without any success? -any thoughts on this , I am trying to secure the wifi even the Smart wifi disk
2) setting up the HYBRID is also easy , no issues , with rj45 cable but why is that the middle button have a flashing red on the  back ground ?
3) I would like to test the Hybrid conncet , with BT BB cable unplugged ? to see if my LAN devices will take over and work on www.-any thought on this please?
4) assuming BB is down EE hybrid takes over and will this have an impact on Bills ?
5)  Can i use the VPN on Hybrid working ?
Thanks for your help.
5 REPLIES 5
Message 2 of 6
Re: Issues and help on Halo and SMART wifi
@Jaffna1974
Are you now an EE customer?
Message 3 of 6
am with BT and just upgraded the package to Halo 3 + , with disk (but my worry is the wifi is open as is see and dont have any authentication
Anonymous
Not applicable
Message 4 of 6
BT/EE WiFi is the hotspot that your router provides to others & isn't connected to your own network.
Message 5 of 6
Thank you, so when initial set up with wps with BT Router > {when you try with other`s phone not on home network , then can login without any issue ? so are they getting free to login ?- {to stop me worrying with security None ON WIFI - hence the question
Message 6 of 6
This explains how BT/EE WiFi works.
