Message 1 of 2
ipv6 activeor not?
In the advanced settings of the hub manager it states ipv6 enabled. Should install this on my network adapter or just leave as ipv4? Just curious thats all. Cheers
1 REPLY 1
Message 2 of 2
Re: ipv6 activeor not?
It is usually enabled by default on NICs. If it isn't, you might as well.
