Message 1 of 14
JVC smart TV won't connect to wifi
Help needed please.
I have a JVC smart TV that won't connect to my by WiFi.
I have a smart hub 2, tried all the usual turn on / off stuff still won't connect.
Scanning WiFi networks find my WiFi.
Tried creating a hotspot from my phone and the TV connects to that
TV reset still won't connect. Any ideas please
13 REPLIES 13
Message 2 of 14
Re: JVC smart TV won't connect to wifi
Message 3 of 14
Thanks , turned it off and I'll have another go at connecting tomorrow
Message 4 of 14
Still not connecting
Message 5 of 14
Try turning off the 5Ghz WiFi on the hub temporarily, if the TV connects, turn 5Ghz back on afterwards.
Message 6 of 14
That not worked either. I have another Home hub 2 might try that
Message 7 of 14
I doubt the problem lies with the Hub.
Message 8 of 14
When I used my phone as a hotspot creating an alternative WiFi connection the TV connect straight away which leads me to think it's an issues with the BT setup
Message 9 of 14
Hmm, have you tried connecting the tv to the hub via Ethernet?
Message 10 of 14
Yeah that works might have to just use a powerline adapter
