Message 1 of 2
L2TP VPN on BT Hub
Hey,
My L2TP VPN wont connect on our new BT Hub via WIFI...
Works fine on Cable/Lan but just wont connect if the laptop is connected via WIFI..
Any ideas ?
Chris
1 REPLY 1
Message 2 of 2
Re: L2TP VPN on BT Hub
Are you connected directly via WIFI or some other in-between device such as a booster, powerline or different AP other than the Hubs actual WIFI?
What is the error message the VPN connection attempt throws, it will always give one when it fails?
EE900 | Nokia ONT | Ubiquiti ER-X | EETV Box Pro (IP Mode) | Unifi CK2 | 6x Unifi U6+ | 4x Unifi SAK Ultra
