Message 21 of 24
Re: LAN issues following fibre installation
It could be as simple as a bent pin in one of the Ethernet cable connectors or the Ethernet socket which is making and breaking the connection.
Message 22 of 24
OK, some progress!!
As I said, there are four LAN cables running into the house.
Three of them are down for reasons unknown, but one is working - so I have repositioned the original router and now have a stable connection.
I have no idea whatever as to why the other three connections went down, but at least I know what the issue is now.
Huge thanks for the replies - you confirmed that I am not mad, and made me check my work - which was important as I had it wrong!
Next thing is to fix the broken connections, but at least I know what the problem is now.
All the best
Bruce
Message 23 of 24
You might have hungry mice!
Message 24 of 24
The thought had occurred!
up to 2 connections now. That will do; getting a decent speed in the house now.
