Message 1 of 11
Laptop not connecting.
Not sure if this is the correct group, apologies if not
Mobile and my main tower PC connect OK, but have tried 2 different laptops and neither will connect to broadband.
Have tried switching off the router for a while before restarting, but still nothing.
It did come back last night, but won't connect again today, grateful for any suggestions.
10 REPLIES 10
Message 2 of 11
Re: Laptop not connecting.
Are these Windows 10 laptops and have you got a WiFi symbol/icon in the bottom right hand side of the notification area (Win 10)?
Message 3 of 11
Message 4 of 11
Sorry but I'm out then if it's Windows 11.  Can you not Google this problem as there is a lot of info out there?
Message 5 of 11
if laptops were connecting before without a problem what has changed?
Message 6 of 11
Seem to recall a similar issue recently, it was the third party anti virus software that was the issue
Message 7 of 11
Yes, I run Surfshark VPN, and I can't open my photo webpage with that on, have to switch it off, but I have tried that, switched it off and no difference.
Message 8 of 11
Nothing, as far as I know, it's a mystery.
Message 9 of 11
Yes, I had already googled it, seems to happen quite often, but none of the answers , suggestions seemed to work.
Thought I'd come here and ask the experts. 😉
Message 10 of 11
Try a factory reset of the BT hub by pressing a pin into the recess button on the rear for about 20 seconds.
When the hub is reconnecting restart, not just a power off,  your laptops to see if that helps.
You should also check that your laptops are not named the same.
