Message 1 of 6
Mac filtering
My son thinks he’s clever by changing his MAC address on his Xbox to stop his internet going off at night, is there a way to do Mac filtering on Bt smart hub 2 to stop this? Or do I just need to keeping blocking each new MAC address from the my Bt app?
5 REPLIES 5
Message 2 of 6
Re: Mac filtering
@Bradbury1977
Its not possible to do that on the Smart Hub 2, you would need to use a different router which supports a MAC address "whitelist", so only approved MAC addresses can connect. If the MAC address is changed, then there would be no connection.
You could disable Wi-Fi on the home hub, and use a wireless access point instead, which has filtering. That would not help on Ethernet connected devices.
Message 3 of 6
Re: Mac filtering
Then the parental controls are redundant, what’s the point of having them if it’s that easy to manipulate?
Ok I’ve have my Bt broadband for some time so now it might be a good time to reassess my options.
cheers mate.
Message 4 of 6
Re: Mac filtering
You will have the same problem with any other provider, as they all rely on MAC filtering, and its easy to change the MAC address on most devices now.
Message 5 of 6
Re: Mac filtering
cheers mate.
Parental controls are essentially designed for younger non tech-savvy children. Anyone thinking that they can defeat tech-savvy teenagers with technology are deluding themselves.
Message 6 of 6
Re: Mac filtering
No you do not need to block each new MAC address, what you need to do is take your son's Xbox away from him until he learns the house rules.
