Message 1 of 11
Max Internet speed through Openrearch socket
Hello,
Would it be possible to have a high-speed connection (150Mbps, 500Mbps and more) through the existing Openreach socket in the house?
I currently have 60Mbps from NOW via modem connected to Openreach socket in my rented house. But I wonder if it's possible in general to get more out of it without drilling new holes in walls (for new wires) or any other physical modifications in the house :). Because I expect my landlord would be reluctant to such physical modifications.
The checker at https://www.broadbandchecker.btwholesale.com  shows that WBC FTTP is available at 1000mbps down and 220mbps up, but I am not sure if it means that it is already possible to connect to existing Openreach socket or a new full fibre line have to be installed in the house.  I just don't want to be in a situation to figure out that physical modifications are required after singing a contract.
10 REPLIES 10
Message 2 of 11
Re: Max Internet speed through Openrearch socket
FTTP does not use the master socket, it uses fibre optic cable to an ONT.
Best you can get through the master socket is FTTC/VDSL.  This is “up to” 80Mb/s but depends on the line.  If 60Mb/s is what you are getting now then that is probably as good as it’s going to get.
Message 3 of 11
Yeah, this is what I assumed but was not sure about.  Thank you for the answer!
Message 4 of 11
It would be worth having a discussion with your landlord about getting FTTP installed - depending on the property layout, the install can be very little disruption and it would improve the desirability of the property.
Message 5 of 11
Yes, good, point! But do they usually drill a new hole near the entrance door to install a new fibre option cable and new socket somewhere in the hall?
Message 6 of 11
The fibre will usually follow the same route as the existing copper, but it is likely to require a new hole to get from outside to inside - this is fairly small, ~12mm, and should be a fairly neat job (although mileage may vary depending on individual contractors).  And there is also a new 'socket' (called an ONT) installed in the hall (or elsewhere, depending on what's feasible) - it's smaller than the existing master socket.
Note that you do need to have a power socket near to where the ONT is installed as it requires power (unlike the master socket).
Message 7 of 11
I see, thank you for the detailed answer!
Anonymous
Not applicable
Message 8 of 11
Does BT still sell G.Fast services, which in theory can go up to 330Mbps download?
Anonymous
Not applicable
Message 9 of 11
My post above was in response to this thread, but seems to have become a new thread in itself:
https://community.bt.com/t5/Home-setup-Wi-Fi-network/Max-Internet-speed-through-Openrearch-socket/m-...
Message 10 of 11
Moved back
