Message 11 of 17
Re: Mesh setup
Halo 3+ has absolutely nothing to do with Digital Voice
Message 12 of 17
Re: Mesh setup
Wasn't aware of that, as BT seem to push it as a benefit
Message 13 of 17
Re: Mesh setup
The only requirement for Digital Voice is a Smart Hub2.
Message 14 of 17
Re: Mesh setup
Foll8wing on from the question on mesh setup, what units are peopke using?
I'm looking at TP-Link devo xe75, Asus zen  wifi xt8/9, linksys velop  pro 6e
Thanks in advance
Message 15 of 17
Re: Mesh setup
I use Deco mesh and have a mixture of 2x M9 plus units and 1x X60 unit, its great equipment and I wouldn't use anything else.
Message 16 of 17
Re: Mesh setup
I'd be surprised it it's cat 4.  That's as out of date as square wheels.  It was only rated for 16Mb/s at 20 MHz!
Message 17 of 17
Re: Mesh setup
Cat 4 was also rated at  100 MHz for ISO/IEC 11801 specification. It was used for 16Mb/s Token, 10Base-T and  10Base-4 (remember that? a fast Ethernet implementation using 4pr at 25MHz),
