Message 1 of 15
Moving from BT Broadband to EE due to router reason
Hi,
I've got BT Full Fibre 900 broadband which came with SH2.
Of course that router lacks of enhanced Wifi connection speed and I won't make use of the full speed using Wifi 5 network.
Do you reckon if by moving to EE I can get away of the contract cancellation fee from BT due to this reason? Also as EE and BT are joined I'm in practice not leaving the provider.
I would not mind remaining at BT if at least I could benefit of the full speed I'm paying for using Wifi 6 but this seems not possible at the moment hence I'm toying of moving to EE.
Tried to contact BT but been told someone would call me back which hasn't happened so far.
14 REPLIES 14
Message 2 of 15
Re: Moving from BT Broadband to EE due to router reason
Err, why not simply buy a third party router?
Message 3 of 15
Well if EE provides a Wifi 6 one why would I buy a third party?
Message 4 of 15
To avoid cancellation fees.
Btw, WiFi 5 will exceed 900M
Message 5 of 15
It doesn't look like I'm having these kind of speeds.
iPhone 14 pro and all I get is barely 400Mbps next to the router
Message 6 of 15
Is that throughput speed or Phy speed?
Message 7 of 15
It's the download speed I get when running this tool on either my laptop or phone.
https://speedtest.btwholesale.com/
Message 8 of 15
What's the Phy (Link) speed?
Message 9 of 15
you mean the speed when it's wired?
Message 10 of 15
No, the speed of the Wifi link between your device and the hub.
