Message 1 of 9
NETGEAR Orbi and smart hub
Hi,
Hoping someone can help. I recently moved from Virgin to BT FTTP. I’ve got an Orbi RBR 850 router and was hoping to connect it directly to the ONT via the WAN as hoping not to use the BT router at all. But after connecting it I’m still not able to get any internet. I’ve changed the internet connection type to PPOE on Orbi but still no luck.
Any suggestions greatly recieved.
BW,
Andrew.
8 REPLIES 8
Message 2 of 9
Re: NETGEAR Orbi and smart hub
Did you enter the correct PPPoE credentials?
Username [email protected]
Password BT
Message 3 of 9
Hi,
Yes.
Selected advanced tab>advanced>ipv6>
internet connection type>PPPoE
login>[email protected]
password>bt
Still with no luck.
BW,
Andrew.
Message 4 of 9
What about IPv4?
Message 5 of 9
+1 for @licquorice Do you have the option for ADVANCED >> Setup >> Internet Setup, choose Yes to using password for internet rather than IPV6. Failing that factory reset and start from the beginning. Best of luck!
Message 6 of 9
yes, with no luck. Only work around i've figured is to connect the orbi to the bt router and disable the wifi from the BT router so effectively using the bt router as a bridge effectively.
Message 7 of 9
I cant see an ipv4 tab on the orbi troubleshooting page
Message 8 of 9
I’d factory reset and start from scratch using the setup wizard.
Message 9 of 9
I’ve done this and the ipv6 changes and it’s working now. Thanks all.
