Message 11 of 12
Re: Need a Router for Wired system??
I would reset to factory setting the tplink and start again  just select the quick setup and when username needed use the one I posted earlier  the password can be anything or just BT
Message 12 of 12
The username and password are the PPPoE credentials required when setting up the router.
