Message 1 of 23
Netgear R6220 instead of BT Hub2
Hi!
I've got an old Netgear R6220 that I got from a friend. I'm planning to replace the BT Hub2 with it as BT decided that I can't change my DNS to anything except what they want.
Netgear has a WAN port for RJ45 when BT Hub has the RJ11 to connect. Will the RJ-45 to RJ-11 cable work with this or will I need to get some other router/modem?
Anybody tried that before?
22 REPLIES 22
Message 2 of 23
Re: Netgear R6220 instead of BT Hub2
What service do you have? That is just a router. The rj11 port on the hub is a DSL port not a wan port.
Unless you have fttp, the Netgear will need a separate modem
Message 3 of 23
I do have a Fibre Essential package, I just have a double socket in the wall where it connects and that goes from the main box on the street, so I assume it's not FTTP then.
Message 4 of 23
No, and the Netgear won't work unfortunately.
Message 5 of 23
In that case, if I want to buy a replacement, what should I look for? Any modem / router combo will work, or does it needs to be VDSL specifically?
Message 6 of 23
Yes, it needs to be a VDSL modem/router
Asus and Tp Link models are popular
Confirm suitability of chosen model here before parting with cash.
Message 7 of 23
While I'm a big fan of Asus routers, the router/modems I've seen have been nothing but trouble, so I'd probably not look at Asus for that!
I'm sure @licquorice will correct me if I'm wrong, but if you are of a certain mindset, you should be able to set up a Raspberry Pi (or similar) with Pi-Hole working as a DHCP & DNS replacement.  All while still using the BT router as the gateway!
Whole house, garden, garage and half the street covered by a Flint 4 - WiFi 7 router
Message 8 of 23
I did set up most of my devices manually, but stuff like TV has no access to change DNS. Same with BT Hub. It used to be an option apparently, but they... well... patched it up. Additionally, when I have friends over, I'd like them to be protected as well.
Message 9 of 23
Protected from what?
Message 10 of 23
Spam, tracking, personal data loss to brokrrs, accidental clicking on an ad because the website makes the "x" to close it super tiny, NSFW randomly showing up as an ad, a lot of stuff actually.
