Message 1 of 2
New build house, ONT set-up help
Hi.
I've moved-in to a new build property where the ONT and media plates are located in the garage, with each room having a connection point. In short; what do I do to connect a device by wire in each room, please?
1 REPLY 1
Message 2 of 2
Re: New build house, ONT set-up help
just connect the ONT by ethernet to WAN port on router.  then connect ethernet from remaining router ports to the plate in the garage - each connection will be to a different outlet.  you may need to buy and a 4/6 port  switch to give you more ethernet connections  then connect devices by ethernet from outlets in each room to your devices
