Message 1 of 3
Old phone sockets
We recently upgraded to BT Full fibre. During this process a new line and main terminal box was installed. We still have the 2 old master phone sockets installed, albeit in a different location.
I am wondering if these 2 sockets and associated cable can be removed. We are not using anything off these 2 points anymore.
Shame I didnt think at the time and ask the engineer if we could remove these.
2 REPLIES 2
Message 2 of 3
Re: Old phone sockets
if you have FTTP and digital voice then old socket are not used anymore.  they are property of openreach not BT but I very much doubt anyone will check if you decided to remove the sockets and tape up wires
Message 3 of 3
Thank you, very quick reply 🙂
