Message 1 of 2
PS5 Port forwarding overwatch
Hi.
Can anyone point me in the right direction. New to BT and already regret it. I play Overwatch 2 and i have a lot of latency.
I am trying to figure out how to port forward from my bt smarthub to the playstation 5.
Where do i give in these codes? when i go to firewall i see external and internal ports start and end.
I tried a couple of them codes but it says amount of ports not valid. any videos soemone can recommend?
I saw a lot of codes online like
playstation 5
TCP: 80, 443, 3478, 3479, 3480 and UDP: 3478, 3479,49152~65535.
Overwatch 2 - Playstation 5
  • TCP: 1119, 3478-3480, 3724, 6113
  • UDP: 3074, 3478-3479, 5060, 5062, 6250, 12000-6400
1 REPLY 1
Message 2 of 2
Re: PS5 Port forwarding overwatch
Port forwarding is normally when you want an open NAT due to present NAT type where as latency needs work to find out what is the cause as it could be anything.
many run PingPlotter as a starting point then go from there. Of course it could simply be server location or you playing over a WiFi connection so some more details would be helpful.
