Message 1 of 5
Playstation portal
I have seen feedback of people recommending just to have my PS5 on the 5ghz channel. With all the other devices on 2.4ghz. Can I change the devices from 5ghz to 2.4ghz manually from the routers settings? I couldn't see where to do this.
4 REPLIES 4
Message 2 of 5
Re: Playstation portal
if you have the SH2 then you cannot split the 2.4/5ghz and it is the device which decides on with to connect 2.4 or 5ghz.  however if you have a hub 6 or a third party router then you can change the setting in router  which router do you have?
Message 3 of 5
Thanks, I have a SH2. I will look at getting a third party router then.
Message 4 of 5
if you have digital voice now or if you have home phone and will be moved to DV then only the SH2 will work with BT digital voice
Message 5 of 5
The decision to use which band is made by the device based on signal strength/quality.
2.4Ghz is slower but reaches greater distance, 5Ghz is faster but doesn't reach as far.
If your device is too far from the hub it won't connect at 5Ghz.
