Message 1 of 5
Poor 2.4GHz signal with smart hub 2
My smart hub 2 appears to have a very weak 2.4GHz signal when compared with the 5GHz signal.
Sitting about 2 metres away from it, the 5GHz is at -44dBm but the 2.4GHz signal is only -78dBm.
My printer is 2.4GHz only and located about 4 metres away from the hub. It has problems connection with such a weak signal.
The previous Home Hub 5 had both signals at a similar strength and the printer had no problems with it.
Is the smart hub faulty?
4 REPLIES 4
Message 2 of 5
Re: Poor 2.4GHz signal with smart hub 2
Have you tried. Changing the 2.4 channel from auto/smart to a specific channel using a WiFi analyser on your mobile to see channels in use and selecting free or less congested channel
Message 3 of 5
Yes I have tried changing the channel. It made no difference to the signal level.
The 'smart' setting had chosen ch1, which is also used by my neighbours VM router. I tried both ch6 and 11 and both had a poor signal
Message 4 of 5
A number of people have Wi-Fi issues (performance and reliability) with the SH2. I use a wireless extender ( a repurposed router) connected directly to the SH2 as a workaround.
Message 5 of 5
