Message 1 of 3
Port 1 Dropping all the time
20:49:52, 22 Sep.
A device connected to Ethernet port 1
20:49:52, 22 Sep.
Wire Lan Port 1 up, Speed 100 Mbps
20:49:38, 22 Sep.
A device disconnected from Ethernet port 1
20:49:38, 22 Sep.
Wire Lan Port 1 down, Speed 10 Mbps
i get this all the time. updated drivers and other bits i am aware of. But this always comes and drops. Managed to stop it somehow for a while but don't know what to do. the whole internet is fine. just my port that does it. no matter which port i change on router. still same.
2 REPLIES 2
Message 2 of 3
Re: Port 1 Dropping all the time
@Bradderrs500
It will be an issue with auto-negotiation, and slight temperature changes can cause timing differences and corrupt the Ethernet Link Pulse. See https://en.wikipedia.org/wiki/Duplex_mismatch
If you fit an Ethernet switch between a LAN port on the home hub, and the LAN port on your computer, the problem should stop, as the switch will match the two rates.
Like this one https://www.tp-link.com/uk/business-networking/litewave-switch/ls1005g/
About £9.50
You would only use two of the ports, and it would give three extra ones if you needed them.
Message 3 of 3
Hi, the current situation I believe is I have a line running into a wall socket from the router. That runs through the house to another wall socket and then I have a Ethernet from that into a switch. But still have the issue even with the switch plugged in.
I believe that is what fixed it to start with. But it still drops every so often. When on games.
sometimes less than others. Maybe like once a night. But tonight it was unbearable and was every 10 min for a few times.
