Message 1 of 4
Port forwarding to use jellyfin
I’m not sure if anyone can help. I have the app Jellyfin I can access it whilst I’m on my home network and Wi-Fi, but I want to be able to access it away from my home network and Wi-Fi, but I’m not able to do that as it doesn’t recognize the IP address I need help to be able to port forward on my smart hub two to be able to access the , I have the IP address for the PC I need to access but for some reason won’t let me get to it.
please can anybody help
3 REPLIES 3
Message 2 of 4
Re: Port forwarding to use jellyfin
Message 3 of 4
Thanks for that, am I right in saying that the internal port needs to be the Jellyfin port number, i.e. 8096 for both start and finish
I need the router, IP address plus the Jellyfin port number to be able to access from the outside
Message 4 of 4
Yes.
You access via your public IP address which will be dynamic. You can set up an IP tracking DynDNS service via NoIP or similar.
