Message 1 of 4
Printer not printing since switch over to BT Digital Voice
Since the switch over to BT Digital Voice a couple of weeks ago my printer will not actually print.  I have uninstalled and reinstalled, cleaned the heads, checked ink which is okay and run a test page which does print but is extremely faint, if I do get anything to print out it is so faint it is unreadable.  Before the switch over it was working perfectly and is not that old or used all the time.
3 REPLIES 3
Message 2 of 4
Re: Printer not printing since switch over to BT Digital Voice
Did you have to change to a  Smarthub2 in order to get Digital Voice?
There is nothing with Digital Voice that should affect a printer.
If it is printing  a test page that is faint and if it is connecting to the Smarthub2 and prints albeit faintly it would appear to be a printer issue.
Message 3 of 4
Yes I did have to change to a SmartHub2 when BT switched me across. The printer would not print all all using the USB cables so I have had to use Wireless but in excel I get lines but no text and with word, no text at all. The only time I get any print is if I use colour and that is very faint.
Message 4 of 4
The printer will not work if you are using the USB cable plugged into the Smarthub 2.
If it is not working with the USB cable plugged directly into your computer it would appear that your printer is faulty. When the printer is plugged in by USB to your computer it is not using the Smarthub2 in any way. You could turn the Smarthub 2 off and the printer would still work.
Have you tried a factory reset of the printer then setting it up again onto you computer as though for the first time although given that when it does print a test page faintly and when it does print it is faint I would still say your printer is faulty and it is a coincidence that it coincided with you getting Digital Voice.
